How does the whole SLI thing work?
So I already have a EVGA GTX 580 and i'm buying a Gigabyte GTX 580 from a guy on craigslist locally.
I was wondering if that card would work properly in SLI with my EVGA one. I wouldn't think it would since the card's board is different. Is the SLI connector in a different area too?
This is the card I'm looking to buy: http://www.gigabyte.com/products/product-page.aspx?pid=3830#ov
I also i have to go a local frys electronics and buy a SLI bridge since I lost mine :P
All that's needed is two identical GPUs (one 580 with another 580) and an SLI bridge. Board manufacturer is irrelelvant, and SLI finger should be in the same area.
As jerm said, as long as the GPU cores are identical they will SLI.
With two different brands (of the same GPU) they may have different clock speeds, memory speeds and capacities.
They will clock to the speed of the slower of the two cards (or not change if they are identical). Also memory capacity will be capped at the smaller of the two cards if they have different memory capacities. (Say one has 3GB VRAM and the other 2GB, then you will only be able to use 2GB) Obviously best performance comes from identical cards (or ones of identical spec), but as long as they are the same GPU core, they will work.
Thanks.
Wow no that is crossfire. In SLI you have to have the exact same card (can be different coolers) with the exact same amount of V-ram. Take for example the Gtx 680 and Gtx 770. The 770 is a rebranded 680 with faster memory, but otherwise its the exact same chip. But they will NOT SLI. Nvidia locks there cards so that this is impossible. A 770 can only SLI with another 770 and both of them have to have the same amount of V-ram. No 4gb cards sli'd with 2gb cards. This is done by Nvidia directly so that you have to have to identical cards (again minus the cooler) for them to SLI.
    What you are talking about is AMD crossfire. In crossfire you can have 2 different cards (7870 and 7950) and the higher card (7950) will downclock to meet what the 7870 is capable of producing. They can have different amounts of V-ram but they will be limited to the lesser of the 2 cards.
Bad example, as the 7870 and 7950 are different GPU s and will NOT Crossfire. However, a 7850 would crossfire with a 7870. They need to be similar (same class; ie 7800 series).
Sorry I know lots more about SLI than crossfire being slightly biased towards Nvidia. Easy to tell apart but hard for me to fully list exactly what you need to crossfire properly.
BAM!  https://www.youtube.com/watch?v=cxc6cb3_y0w
linus pretty much covers it in this video
Is the higher memory card capped or will it not work all together? I've heard both and linus says it won't work all together.
