I like when my PC boots very fast. I was thinking in spending money to buy an SSD for fast boot times. Currently I'm using 1 TB HDD and so the boot times are very slow to the point where I can't stand it.
In maks hacks episode Max talked about Sleeping mode, I tested it out and it actually does the thing even on my HDD PC boots super fast. But does it use extra power and if so how much? Would you rather recommend getting an SSD or just use Sleep mode. Note that I only want fast boot times. I know SSD also makes programs load faster, but really boot times is what's more inportant to me. So is it worth using sleep mode or SSD for fast boot times.
If boot times are what is more important to you, I'll wager you've never used a machine with an SSD before. I'm not bashing you, I was the same way before I got mine. To answer your question, I've always used sleep mode when I could rather than restarting. Waking up from sleep isn't going to get a whole lot faster by using an SSD, but starting up time will get much closer to HDD wake up time with an SSD installed.
That said, having an SSD installed seems to make EVERYTHING faster. Your system as a whole will be much more responsive. If you can afford it, I will always recommend an SSD as one of the best upgrades you can do for your machine. Now that I've had mine for 18 months, I can't imagine having to revert back to a mechanical drive.
Well sir, you really inspired me to buy an SSD! But in general sleep mode uses a lot of power? Is it worth it if you have a HDD or just rather turn the whole system off.
Sleep mode is considered a low power state. Your computer isn't completely powered off. When your computer is fully shutdown, it still consumes some power, probably around one watt. When in sleep mode it uses closer to five watts. That's still significantly less than when it is powered on. So ultimately, you can still enter a low power state with your computer and have it ready to use in a matter of seconds with a traditional HDD.
But I'd still like to stress that SSD is benificial in more than just startup times. Startup times are just icing on the cake in my opinion.
I'd say get an SSD, personally i have never liked sleep mode purely because of the added stress it places on componants. Think of it like a dimmer switch, if your lights on fully its fine but if you dim the light (drops the flow of volatage/amps) the switch hums as it chokes the flow. Its similar in a PSU, its capable of doing it but it reduces the life on the parts involved (they all have a lifetime exspectancy and this choking effect is hard on any part).
The other thing you need to note is that, with some SSD's you should not use sleep mode or any kind of power saving options, SSD's have a "garbage" mode , which is basically a time when they clear out un needed data and re arrange data cells etc. Usually this is set to kick in when the SSD in not in use, if you have sleep mode or power saving turned on it effectively stops this from working and you end up with an unstable/blue screening SSD (usually wont even pick up in bios/boot). So make sure if you buy a SSD you read what is required. You may of seen the fix for this when people are told to disconnect the sata cable but leave the power on the SSD then leave the PC running for 30 mins, this is what happens when you have power saving turned on with some SSD's :)
The sleep more you are all talking about is suspend to ram. It's fast but you can't completely power off your system. I prefere suspend to disk which essentially dumps the ram to a disk and lets you power off completely. It needs around the same time to wake up as a cold boot but all your programs are still running and you don't have to wait for something to get ready.
AFAIK there is no problem anymore with SSD's and power saving modes. I also use a SSD for the ram dump.
