How does it look
How does this look for my first gaming build.  Any advice or does she look fine
If you can make it better without increasing price or reduce price without losing performance would be great.
PCPartPicker part list: http://pcpartpicker.com/p/CGeB
Price breakdown by merchant: http://pcpartpicker.com/p/CGeB/by_merchant/
Benchmarks: http://pcpartpicker.com/p/CGeB/benchmarks/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Microcenter)
CPU Cooler: Corsair H60 74.4 CFM Liquid CPU Cooler ($49.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($132.98 @ SuperBiiz)
Memory: G.Skill Value Series 16GB (2 x 8GB) DDR3-1333 Memory ($82.99 @ Newegg)
Storage: OCZ Vertex 3 Series – MAX IOPS Edition 120GB 2.5" Solid State Disk ($89.99 @ Newegg)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($234.99 @ Microcenter)
Case: Zalman ZM-Z9 U3 (Black) ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Cooler Master Silent Pro M2 620W 80 PLUS Bronze Certified ATX12V Power Supply ($64.99 @ Newegg)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer ($59.99 @ Newegg)
Total: $885.90
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-02-10 16:51 EST-0500)
Hmm, look into some AsRock Mother boards, some pretty nice features for the price.
If you can, maybe push for an FX - 8500k.
An you may want more storage than just a 120Gb SSD.
Other than that, I see nothing wrong.
For $25 less than a H60, you can get a Xigmatek Dark Knight that easily out performs it. I also recomend looking for some higher speed RAM, I recomend some 1866 Kingston HyperX Beast http://www.newegg.com/Product/Product.aspx?Item=N82E16820104367&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
thanks and im adding a old 500 gb hdd from a old computer.
As for the ram I was told latency is better than speed. And i do later on want to over clock how will that do?  also ram is 40 more than current
To keep price down i cant go to a bigger cpu without cutting stuff out.       im debation in keeping the motherboard or going to this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157262&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
Current config now is
PCPartPicker part list: http://pcpartpicker.com/p/CHtk
Price breakdown by merchant: http://pcpartpicker.com/p/CHtk/by_merchant/
Benchmarks: http://pcpartpicker.com/p/CHtk/benchmarks/
CPU Cooler: Xigmatek Dark Knight II SD1283 Night Hawk Edition 89.5 CFM CPU Cooler ($46.99 @ Newegg)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1866 Memory ($129.99 @ Newegg)
Total: $929.90
(Generated by PCPartPicker 2013-02-10 18:19 EST-0500)
If you are gaming you don't need 16GB of RAM, 8GB is more than enough. I would go for less RAM and invest the money elsewhere (CPU or GPU). I would also recommend a cheaper cooler and invest the money in a better graphics card. Not saying that the 7870 is bad. It is great for the money, but if buy less RAM and a cheaper cooler you could afford a better card I think. About the RAM frequency/latancy I would say frequency is more important, just don't go with somthing with a lot of latency compared to others and you should be fine. CL of 9 or 10 is good you don't need less. But the memory clock is more important than latancy. But remember if gaming you don't need more than 8GB, invest the money elsewhere.
What graphics card would you recommend?    As for cooler thats pretty cheap and i still want to over clock later.  You have a better one? As for ram i just liked not having to switch it out at a later date and i use adobe once and a while like photoshop idk if that matters or not.
So i have shrank it down to these
PCPartPicker part list: http://pcpartpicker.com/p/CJ9W
Price breakdown by merchant: http://pcpartpicker.com/p/CJ9W/by_merchant/
Benchmarks: http://pcpartpicker.com/p/CJ9W/benchmarks/
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory ($99.99 @ Newegg)
Total: $899.90
(Generated by PCPartPicker 2013-02-10 21:48 EST-0500)
or
PCPartPicker part list: http://pcpartpicker.com/p/CJPU
Price breakdown by merchant: http://pcpartpicker.com/p/CJPU/by_merchant/
Benchmarks: http://pcpartpicker.com/p/CJPU/benchmarks/
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($79.98 @ Outlet PC)
Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($39.99 @ Newegg)
Total: $761.91
(Generated by PCPartPicker 2013-02-10 21:49 EST-0500)
But really like the gigabit board and want to be able to overclock in the future.   I Dont actual know my budget yet so cheaper is always better without losing the performance though.
And im going with a black and blue color so no red ram or anything (its killing me $50 on ram becuase but o well)
8GB is enought for PhotoShop, what you could do is get one 8GB stick, so in the future you can easily upgrade to 16GB in dual channel. The choise is yours.
