Been at it for three hours. I can't screw in the hinges.
Bump. I'd like to be able to use my computer tonight.
:| bad description, you're not telling us anything. Once can guess you want support for your chassis "R5" i know it must be very popular and known chassis but :( ... yes, I don't know what you're asking for.
You can change the side at which the door swings however I can't find put how. I removed the door and am not sure as to how you put the hinges back on even after 4 hours so fat of messing with it.
means you broke it :)
maybe try youtube... review video usually contains such = if its some feature of your chassis.
Every video mentions it this far. All I did was remove two screws...
so this guy disassembles whole thing and puts it back together...
with proper timing.
I misplaced a screw. Going to look for it in the morning. Right now I'm having ram trouble (error 53).
Fixed it. Screws weren't the same as aforementioned.
