So of course, cables from mice get stuck in places, or pull your mouse off the table or just cause friction with the table causing something that might be regarded as similar to "acceleration" or just different speeds of the mouse depending on what part of your table your mouse is on because of the friction.
I've read a lot of people talk about the mouse bungee from razer but some negative things I've also heard is how it has some sort of spring, that makes mouse movement not perfectly accurate either, although of course not getting stuck on things on your desk
Another thing is to just seletape parts of the cord into a "loop" on your desk so that you have enough space to move the mouse around and this is what I do, but the very top of the loop touches the monitor stand, which means it's harder to move the mouse around.
So what do you guys use and what do you think? I've been recently thinking that actually none of this really matters, as long as you get used to the so imperfections for example needing to apply more force on the mouse in places of friction.
To put things in perspective I'm a competitive tf2 player so maybe I'm thinking about this more than other people do or should XD
