When ever i am playing a game, sometime the game terminates and I get the display error or the computer hang up and i hve to hit restart.
WIndows 8.1
A10-7850 APU
8GB DDR3 Ram
120 ssd
750w psu
gigabyte f2a88xn-wifi Motherboard
Try re-installing drivers. Check your mobo drivers as well. I had weird audio drop-outs on my asus board before I finally found a decent driver that also helped my 'bad overclocks' on my gpu's.
Ok will try that.
I came here thinking you'd found a solution and wanted to share it. You should have named the thread "How do I solve" instead of "How did I solved"
I solved it though.
