I got 2 1tb 7200rpm hdd and was wondering how to run them in rai heard it speed up my load times
Your motherboard will have a RAID utility that will be a buttom press on startup (manuals ftw) after that you can pretty much just follow step by step keeping everything default and making sure you make it RAID 0. Note this will wipe all info on both drives and make the failure rate 2x as high because if either drive fails the information on both drives will be useless.
