How do I set a static Vcore on my board? Any tips for OC in general?
I have an Athlon 750k and a GIGABYTE GA-F2A85X-D3H, when I enter the voltage settings in the BIOS and try to set a static value where it says "auto" for the CPU Vcore and NB voltage nothing happens, I type in a value and press enter, then it just says "auto" as if I had done nothing, I need to raise this voltage and I was wondering if anyone could offer some tips on how I could get the values to stay. I am also OCing for the very first time and if anyone has any tips on OCing this CPU and the RAM I would like to know them, thanks.
Turn off c6 state, cool n quiet and turbo core (I think this blocks it) To get a clear view of the overclock you are attempting.
Power saving options tend to hinder when overclocking. You can try put them back on if you are finished though.
If the board has LLC, try turning that up a little (not to the highest, but maybe the second highest).
I turned 'em off and figured out that the way to set the voltage on this board is as follows, you have a stock Vcore value, and you add +0.XXX to that in the Vcore field, not you set it 1.4V right away, you take the stock 1.3 and add +0.1 to that in the Vcore field, thanks for the help.
