Hey guys,
I am so confused on how to get my Red Hat 7 to run in guest in Vmware workstation 12.5 to use 3D acceleration. I am using Windows 10 Enterprise x64 as the host with Red Hat as the guest. I can install the VM’s just fine and install VMware tools and update everything using yum update. But I cna’t get it to enable OpenGL.
My system is a Asus X99-WS E workstation, 64 GB DDR 4 RAM, Nvidia Ge Force 1080 TI.
I keep finding a guide on something called Mesa graphics and I follow it but it does not seem to work for me.
Is there a guide out there for how to get 3D support enabled in Linux as guest with Windows 10 being the host using Vmware workstation 12?
Thank you for reading this.
