How do I get my discrete card and my APU to work together?
So I recently addded an XFX Radeon HD 6670 card to my APU based system: http://pcpartpicker.com/p/14RBR I'm having an issue getting the card and the integrated graphics to work together. When I run benchmarks and FRAPS my fps are pretty high, but when I play the game there is a lot of studdering. If i turn off dual-graphics and only run the card, I don't have any issues. What can I do to get them to work together properly?
> try uninstall drivers, run driversweeper  http://www.guru3d.com/content_page/guru3d_driver_sweeper.html , then re-install the latest cerified driver suite.
>try enable/disable of the v-sync option.
Most likely will work with that suggestion.
