I need I help I just built my pc and I purchased a copy of windows 8 64 bit pro and I copied the files to a pny 32gb USB and went into the boot and clicked on my USb that was listed and I goes to a black screen and says insert proper media device... And press any key and nothing happens please help
Did you make the usb drive bootable before you put the iso. on it?
Some motherboards (for example some Gigabyte boards) do not take kindly to USB bootable devices.
Make sure your usb drive is bootable and that you simply didn't just copy over files to the drive.
If your pc just rejects usb bootable drive then resort to using a disc.
