I have a 59fps video that I want to convert to 30fps so it will take less time to upload to Youtube. It is already rendered as an mp4 using H.264. How can I do this in Premiere. Every time I try to it lowers the quality of the video, and when I make it use the same bitrate the video is just as large.
Don't worrie about that youtube makes it 30 FPS before it even uploads so you should be fine but if you are that paranoid when your done editing it in the rendering options in most video editors you should be able to render it out into 30 fps anyway that also speeds up the rendering process.
I know this is really late but the problem was it lowers the bitrate of the video. I have tried setting the bitrate to the original quality but the file size doesn't go down.
