I recently bought a wifi card from tp link.
link: http://www.amazon.com/gp/product/B005FUGPP4/ref=oh_details_o05_s00_i04?ie=UTF8&psc=1
i was wondering how do I get it connected. The driver software came on a little disc. And it won't fit in my optical drive. What do I do?
The little mini discs work just fine in your PC's disc drive. there should be a small indent the size of that disc in the middle of the optical drive's tray. just set it in that spot and it will load up fine..
i have this card but it keeps saying "please install network adapter" on the software i got with it any ideas?
Did you try downloading the driver from the website?
http://www.tp-link.com/en/products/details/?model=tl-wn751nd#down
yep the latest and double checked it was the right ones.
