How do i connect 4 screens to my desktop
should i use a vga splitter
Just get a graphics card that can support 4 monitors
What graphics card do you have now? it needs to be able to support multi monitor configurations.
its a quadro
what model?
guys im just gonna try doing it on my laptop with the amd10 how can i do it now
You mean an A10?
It can support 4 monitors, but you have to have enough connections on your laptop to do so. A recommendation is to buy a docking station with four connections. I don't know if any docking station has the throughput to handle four monitors, though. You may have to check on that by Googling your make and model of the PC + "docking station".
thank you
