How capable is this build?
I live in Australia and computer prices over here are some what terrible and i'm on a budget I was wondering how this build be in gaming? I was hoping to be able to run games at 1080p maxed out settings and sooner down the line adding another graphics card, Here's a link to the build
http://au.pcpartpicker.com/p/zQvW
Any help would be really appreciated :)
I can only provide a semi-educated opinion as I don't know the prices in Australia but here's my thoughts.
I would suggest trying to find a way to at least put a 7870 in that rig.  It's a bit more expensive but it would be better than the 7850 in most if not all games.
Keep in mind that an SSD will only improve loading times, not FPS in games.  If you already knew that I apologize, just something to consider.  So one option could be to drop the SSD and invest that savings into a better Video Card as you want to game at 1080p.
Another thing is, I very much doubt you would need an 850W power supply, it seems that would be overkill for your rig.  I would think a 600W or a 650W would be more than enough.  You could downgrade that and then upgrade the Video Card as another option.
Other than those two things you seem to have a pretty solid build.  You didn't mention that you already have a Keyboard and Mouse, and since you included a monitor I feel I should throw that in, and make sure you include that in the cost if you don't have that already.
I think I've covered most of my bases here, don't take my opinion as fact, I'm sure others will have good advice for you as well.  Good luck with your rig!
Thanks for the help! I have a older keyboard and mouse at home which I plan on using for a while, I thought the power supply might have been over kill but wasn't sure, anyway thanks for the help.
