How can i make my PC better?
i think i have finalized my new pc, i want to run crysis 3 maxed out everything triple monitor resoultion 3280x1024. will this pc be good enough? thanks in advanced. -Kevin
Specs: http://pcpartpicker.com/p/GZjy
If we could see the components, we could help.
Okay........ what are your specs?
SPECS PL0XXX!
GTX TITAN 3-way SLi with i7 5890k
I looked at this profile and found his old build...meh this doesnt help
AMD phenom ii x4  quad core AM3 Processor AMD radeon 6770 1 TB 7200 RPM hard drive Liteon DVD Burner 8 GB 1600mhz corsair DDR3 RAM 650 Watt Corsair PSU ASROCK 960GM/u3S3 FX MOBO.
If you get a 128mb Drr1 stick on shove it into the drr3 ramslot it should unlock it to 12gigs of ddr4 RAM because ddr1 plus drr3 equals ddr4. You should also get a pentium 3 and shove it in any slot. It doesn't matter aslong as some of the pins are in the slot. It should automaticly OC it to 45ghz. For the GPU you should get atleast four GTX titans for maxuim GRAHICKSS. You also need a 1 WORM drive too. After all that you may have some overheating so I would get some guacamole and smear it on everthing. You should be able to run anygame on this system. Oh yeah forgot to mention but you will need an Fm1 mother board for all this to work properly.
what is your specs BTW?
Just overclock that Pentium 3 to 85 GHz, you'll be fine. It won't catch fire or anything. I do it all the time myself.
I got my homemade pentium 5 ( a p1 plus a p4) up to 1 terahertz. Had to use jelly for thermal paste though. That is what you should do to make your pc better.
And remember, silicon and water are like natures best friends. So give it a good hose down after you finish building it.
Don't forget to nuke it from orbit.
i thought i used toothpaste?
1 7950 and you expect to run 3 screens maxed out crysis 3.
Good luck lol
[url=http://pcpartpicker.com/p/H3rG]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/H3rG/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/H3rG/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-fd8350frhkbox]AMD FX-8350 4.0GHz 8-Core Processor[/url] ($199.99 @ Newegg)
[b]CPU Cooler:[/b] [url=http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr1]Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler[/url] ($32.98 @ Amazon)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/gigabyte-motherboard-ga970aud3]Gigabyte GA-970A-UD3 ATX AM3+ Motherboard[/url] ($104.99 @ Newegg)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/kingston-memory-khx1866c9d3t1k24gx]Kingston HyperX T1 Series 4GB (2 x 2GB) DDR3-1866 Memory[/url] ($47.09 @ Amazon)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003]Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive[/url] ($79.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/kingston-internal-hard-drive-sv300s37a120g]Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk[/url] ($98.58 @ Amazon)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/sapphire-video-card-100354xtl]Sapphire Radeon HD 7870 XT 2GB Video Card[/url] ($234.99 @ Newegg)
[b]Wireless Network Adapter:[/b] [url=http://pcpartpicker.com/part/asus-wireless-network-card-pcen10]Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter[/url] ($21.99 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/zalman-case-z9plus]Zalman Z9 Plus ATX Mid Tower Case[/url] ($45.98 @ Newegg)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/rosewill-power-supply-rg530s12]Rosewill Green 530W 80 PLUS Certified ATX12V / EPS12V Power Supply[/url] ($57.98 @ Newegg)
[b]Optical Drive:[/b] [url=http://pcpartpicker.com/part/samsung-optical-drive-sh224bb]Samsung SH-224BB DVD/CD Writer[/url] ($16.98 @ Outlet PC)
[b]Operating System:[/b] [url=http://pcpartpicker.com/part/microsoft-os-wn700404]Microsoft Windows 8 (OEM) (64-bit)[/url] ($89.98 @ Outlet PC)
[b]Total:[/b] $1001.52
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-03-02 16:41 EST-0500)[/i]
Something like this would be alot better. Have you ever tried tripple screen gaming though? I have tripple monitors and find it very disorienting. Personally I would just invest in a nice 120htz monitor instead.
You're probably going to need to either get a dual graphics card configuration or a single GTX Titan to max out Crysis 3 across those three screens. I would really suggest either two Radeon HD 7970's, a 7990, or a GTX Titan.
That is how I keep my north bridge cool. I just leave the hose running on it then the water goes into a bucket which then goes to another hose to outside.
Ohh.... no, you are all fucking idiots, and have no clue, i learnt from the best of the best here.
Buy a fucking APU!!!
Are apus any good?
No.
