Hi.
I'm using windows 8 on an SSD with a HDD for storage and a third one for Ubuntu. Quick boot is enabled so when I shut down the machine it goes into hibernation. The problem is that I can't access the storage drive from Ubuntu this way and I really like to boot in less than 10 seconds with quick boot.
Is there a way from windows to disable the hibernation just in the storage HDD? To tell windows just use the SSD for that?
Thanks
