How can I create a desktop shortcut for a location in Nautilus?
Hi fellas!
I want to create a desktop shortcut for other-locations:/// in my Ubuntu 19.04. I can’t for the life of me figure out how to do it.
It would be nice if the Nautilus instance that opens that location would be a root one too.
I’ve tried making a .sh script with a simple sudo nautilus other-locations:/// line, but that requires execution through terminal.
Do you have any ideas how to make this?
Thanks!
Did you try a symbolic link?
ln -s /source /link/location
in your case
ln -s other-locations:/// ~/Desktop/linkName
Yeah, but it doesn’t work for some reason…
Opened up the terminal and pasted ln -s other-locations:/// ~/Desktop/Computer.
An icon was created. Unable to access it.
In properties it is noted that the link is broken.
I usually install thunar to have a better file manager with better bookmarking but…
I’d just bookmark the other locations you want. Or make a symlink to them.
Also other locations is just a label in nautilus. It pulls up a list of devices either from mount or something else.
Try gnome tweaks.
Yep. And that is exactly where I want to land when I open up my fake…
My Computer.
And I want to land there as root.
But I can’t get to that point :frowning_face:
Try gnome tweaks.
I have Gnome Tweaks, but what do I do with them for this one? :smile:
Look for nautilus and set the default screen?
Maybe this will help? Maybe it’s a $path issue
