I'm planning to build a PC with this motherboard http://amzn.to/111HOGl and this case http://amzn.to/YFid7p
The case comes with 4 built in fans a front a side a back and a top fan. I also want to install 2 extra fans, 1 for the top and 1 for for the side panel. I'm sort of new to pc building and i'm unsure how I will connect all the 6 case fans when the motherboard has only 5 fan headers and one of them is for the CPU fan. I know that you can connect a fan directly to your psu but unsure how and can you just use the 3 pin connector to connect it to the PSU? This is the PSU i plan to get http://amzn.to/1791dG3 .Also will the fan cables be long enough to connect to the fan headers or will i need a fan cable extender?
Thanks
