Hey guys. I just ordered a new Case ( Sharkoon T28) And the Problem i have now , while the Building of the PC otherwise is clear is : How am i going to connect Fron I/O Without the Motherboard Manual ? For someone who cares , it´s a AM2 Motherboard . And yes , it´s kinda stupid , but i want to keep that Processor and Mobo. Dont Ask why.
Look up the pin out for the OEM board, that will give you all the info you need to connect it all up. the pin out for almost every connector is on the web.
The Problem is , that the Front iO Of this Machine is kinda Cramped up together all in one Plug :P
If you could give the name of the OEM system that would help me and others see what kind of problem you face. You may have to do a little splicing of connectors to get it to work.
the manual of the motherboard has diagrams of the connectors (usually), try to find the model and brand, or just take pictures and dissamble the old case so you see witch cables are for what (follow the cables and see witch ones are for leds or buttons etc.)
It´s a Packard Bell Imedia S1300
the mother board used the standerd ATX pin out for the front I/O so every thing should just plug in. It's also the same board used in some Aacer systems, the make is DA061L-3D. have a link with every thing you should need to get it connected http://www.findlaptopdriver.com/da061l-3d-front-panel-motherboard/
