How best to share a DP 2.1 monitor between Mac and PC
What’s the best way to share a single DP 2.1 monitor (has both DP and USB-C display inputs) with both my PC and Mac?
I have the Combo DP 1.4 KVM but don’t think that will work with a 5k2k panel, so trying to find a solution. Is there a USB only KM device for sharing all the USB accessories and then I connect and switch the monitor input separately? Here’s the exact panel I’m trying to work with: 45" OLED Gaming Monitor - 45GX950A-B | LG USA
Thanks!
Yes :slight_smile:
You can use this in a roaming feature with picture-in-picture mode activated.
