Hi guys,
i could really use community help before i make a mistake i might regret.
in short i’m about to replace my monitor. but i’m confused why i’m getting a resolution option that my macbook pro mid 2012 doesn’t support. i’m currently running 3840*2160.
The monitor i’m planning to buy is the “LG 43UD79-B” a 42,5 inch panel.
2yr’s ago i bought one for my wife and she love’s it. we bought it for €700 no there is a deal where i can buy the same monitor for €470…
So this morning i connected here monitor to my setup in order to test it.
The monitor i’m replacing is my 30-inch 3007WFP-HC. (bought in 2007 for €1412)
that has a max resolution of 25601600
And my laptop is a 15-inch macbook pro mid 2012 that supports a max resolution of 25601600.
i believe it’s this one.
https://everymac.com/systems/apple/macbook_pro/specs/macbook-pro-core-i7-2.6-15-mid-2012-unibody-usb3-specs.html
Later this afternoon i’m getting a €30 cable to test out the active dvi to mini display port adapter from apple i’m running for years. i’m doing this by running this dvi-d to hdmi cable in between.
my final plan is to also connect my 2009 mac-mini dual-core to the same monitor it has the same max resolution… i would be running both computers side by side. This LG monitor can display both computer signals , in fact it can display up to 4 computers at the same time… 4*21inch display.
Here comes the strange part. Currently i only have the Mini Displayport to Displayport cable at home so i connected my macbook pro to the LG monitor. and in system Preferences under display i’m seeing LG-Ultra HD display 30.5-inch (1920*1080) Nvidia Geforce GT 650M 1024 MB.
Then going to Display preferences selecting Scaled i don’t see the 25601400 the display is suppose to support (perhaps when i get the dvi-d to hdmi cable later).
But the only resolutions i see are 38402160 (low resolution) and 19201080
and then the ones i’m not interested in. (but for the sake of accuracy)
1600900 (Low resolution)
1280*720
1080P
This screen is absolutely massive the speakers are good enough to watch Level1Techs so what more could you ask for
But the big question is how is my old laptop doing this?
i was planning to run 25601400 it’s not the 25601600 i’m used to but if it means replacing my older screen that has no OSD and has a buzzing noise when you dim the display… so i keep it running max brightness or where my earplugs and don’t notice it …
one downside of this monitor is that it has no usb-hub but that’s ok for the price.
i’m afraid my computer is doing sum strange upscaling costing my to much resources so i won’t able to run my vm’s and stuff that’s the main reason why i’m using my computer at the moment…
if i can’t do that… than i’d much rather just keep my old screen…
i would love to hear you input guys…
for now i only bought the €30 cable so that’s not a real waist… but don’t want to give away my old 30inch buy the €500 screen and discover it was a bad decision…
The deal lasts until tomorrow midnight.
Thanks for all you help guys appreciate it…
