How am I doing so Far?
I would go and get Windows 8.1. It is not as bad as people say. I would definitely recommend it. You could also get StartIsBack.
well the thing is i would not buy Win 8 because i don't think it's anything to spend money on but windows 7 hell yeah it's good why wouldn't i support a product that's good
well the 4570 that i plan on buying isn't as expensive as the Xeon that was suggested but the 4670 is more expensive than the 4570 which is what im planning on purchasing but there's a Xeon E3 1220 V3 that's priced similar to the 4570 so i'm thinking of taking a look at that
The thing with the 1220v3 is that it doesn't have Hyperthreading like the 1230v3 or the i7 4770, so it ends up being almost the same thing as the i5 4570 you're looking at. The 1220v3 is clocked at 0.1 GHz less, but it has an extra 2 MB of cache, so I would expect them to perform almost the exact same. Either one isn't a bad choice if you have a budget that's about $200 USD.
So other then somebody's opinion on going amd vs intel am I really that good
Yeah, It'll suffice for most games.
So it's all built and everything but the western digital is not being recognized by windows i go in Device Manager and windows says it there but i cant get into my drive help would be most appreciated
you probably need to make a partition on it, in diskmanager
System manager> Computer manager > diskmanager.
thank you you are a life saver
http://pcpartpicker.com/b/OMu
its done and there are pics
Very nice.
*update*
one of the fans failed
Consistently 40 degrees Celsius
ordered extra SATA Cables to connect that DVD drive
Some cable mangement to make it look less atrocious
Monitor is starting to fail.
add me on Steam Peddlar
add me on Origin XxNepzZzxX
You are all beautiful people
update
added 8gb of ram (2x4) for a total of 16
added the MSI R9 390
going to get a 1000 watt PSU probably from corsair
Going to add more drives
