How about this build for 3d design?
http://pcpartpicker.com/user/Obstinated/saved/18yw
Old CPU architecture
motherboard power delivery is too weak
Incredibly low quality power supply
I don't think the Source 210 will fit that CPU cooler either.
can u recomend me something better, i really have no idea XD
I rebuild the original build to try to fix the mistakes
Wut?
The 8320 isn't the old one. That is the 8120.
The M5A99FX has plenty of power delivery for that CPU. You can hit 5.0Ghz with that board.
But yes that PSU is crap and the case won't fit that cooler.
i fix the build XD sry for that but i forgot the case XD can u recomend me one?
http://pcpartpicker.com/p/3Gup9 Intel Xeon's are really great at this kind of stuff, and really a gaming graphics card in this price range is going to be faster than the low end FirePro stuff.
I'd jump up to the 1230V3. It is only a little bit more and you get HT.
Good call, I always assumed all Xeon's had hyper threading. I edited it in there :)
if you had to reduce the price, where you cut?
Motherboard to this: http://pcpartpicker.com/part/asrock-motherboard-b85killer
And it would be a good performance hit, but the graphics card: http://pcpartpicker.com/part/asus-video-card-gtx660dc2o2gd5
Or you could go AMD with an 8320 and the mobo you had on your build
thanks, another question, I see u get 2400Mhz RAM, but the Mobo only suport 1600Mhz is it any truble and do  get faster RAM worth it?
The 2400MHz ram seems to be cheaper and the motherboard can support the 2400MHz ram, you just have to set the XMP profile or overclock the ram manually (you will most likely have to set it manually but its not very hard)
What 3d program are you intending to use?
it is not for me so im not really sure XD
