Hotglue a mini fan to SN850 or move it
I have WD Black SN850 which came without heatsink. I bought active heatsink to it as the temperatures soon went out of control as my 3090 is just below it. The fans however are not high quality and after six months became noisy.
I know I have option to move the SSD to the bottom 4X PCIe slot with PCIe adapter card which would I assume work with negligible performance penalty. I have case fans in the bottom, it could be that passive heatsink might cut it.
If I am however to continue to live dangerously, I was thinking could I buy one of the noctua’s mini fans and somehow hot glue it to a decent heatsink I have attached into the NVMe? Has anyone done this?
AFAIK all M.2 SSD are rated for 4x speed only and there is no performance penalty for using any of the two slots.
I even think there is a cost advantage of not spending and subsequently experimenting with fans and hot glue.
Not to mention that hot glue in a warm area wouldn’t hold for very long, could get messy.
I put this heatsink on my WD Black SN750, since the official drive with the WD heatsink was 50% more (£50 more for me) than the one without.
It looks just like the official heatsink and is a chunky piece of ribbed aluminium with 45 degree grooves, except without the WD branding and saved me £35 vs the official heatsink one.
Don’t know how effective it would be next to your GPU, I only have a RX 5700 and I don’t really check component temps.
I have used a Noctua 40mm as a heatsink fan for many hundreds of hours on my 3D printer and it still works great, they are on the pricey side though. I would rather avoid active cooling if I had to. Myabe look at the heatsinks with heatpipes.
Thanks for the advice. Good point. The lower PCIe slot goes through the chipset though. Does this matter at all?
Great to know this!
I dont think M.2 SSD positioning matters. The lower one should be preferrable because of better heat dissipation.
Only worry about cooling the memory controller/ram if the ssd has it, the flash likes the heat.
