Hot LAN box
TL;DR has any one water cooled an itx gpu? if yes what card with what block?
This past summer I built a lan box in a prodigy M case. my "problem" is the open style direct cuii cooler is pushing hot air down and its getting trapped around my cpu and memory. i have 2 120's intake on the top. 140 rad on the rear and a 120 fan on the bottom  for exhaust. Water cooling is what i'd like to do but space is tight.- real tight.  so tight that my current gpu is touching the power supply.
1st idea is to squeeze  a 240 rad at the top and use angled fittings to send the tubing over the psu and around the gpu. I am not confident that this will work at all.
2nd idea is to water cool an ITX sized gpu. the reduced length of the card would give me ample room to deal with tubes.
3rd and least favourite idea is to say screw water cooling all together and just use a blower style card.
A picture of the current build would probably help me explain things better... I'll try to update with a picture.
