Wi-Fi drivers used:
https://github.com/morrownr/8821cu-20210118
Instructions used for patched realtek compatible hostapd:
The instructions seem different than what I remember following, or maybe they’re in a different place, but here’s the link the readme gives:
GitHub - pritambaral/hostapd-rtl871xdrv: Hostapd driver for RTL8188{C|CU|CUS} wifi chips.
I desparately want to pi-hole the smarr tvs in my home to cut out all the unnecessary junk loading but still allow the device to be used.
E-waste should not exist. I have a very, very old 64-bit machine with just under a gig of ram (mismatched sticks, I had 1.5+ G but either sticks failed or I placed them elsewhere, not with me.)
I want to just run Debian because I got the drivers working in a VM. The issue is, I would have to run one hell of a complicated firewall setup, making that a no-go, or resort to figuring out how to use hostapd.
The issue is, I can’t use the drivers that I have installed to do this (I think, who knows) but either way, I can’t just setup hostapd because the realtek drivers that I use (maybe) uses some different version of something that hostapd no longer uses.
So I try as I might and I DO get hostapd patched–except now I have to copy those patched files (which I cannot find) and copy them to the hostapd foldee.
Then, I can install hoatapd. And that’s just tp get it installed.
Once I get that far, however long that will take, I’ll definitely nesd some serious assistance setting up, no experience at all with it.
I want to get this thread started and will update with the exact driver I’m using, exactly the instructions I’m following, and exactly where I’m stumped on the file copying.
Hope you all can help. I did have the opportunity to use a wifi router with its own built in firmware, would be really cool if usb wireless cards had built in stuff so it doesn’t need drivers.
