Honey, I may shrink my PC
Hello members of TekSyndicate.com
I am looking to do an upgrade for my birthday (the 15th or October), and for the upgrade, I was considering shrinking my system down to mini-itx from my current awkward OEM form factor that is somewhere between mid and micro tower, and put the system in one of those newfangled EVGA Hadron chassis. Do you think this is a good idea? Why or why not? State your reasons carefully and make sure your thesis is presented in a well-written, well-laid out 10 paragraph essay. LOL JK. But seriously, do you think this is a good idea?
System specs:
i7-3770
GT 620
Adata OEM DDR3 1600 4gb x 4
OEM asus motherboard h77 micro atx
2TB Seagate barracuda
256gb crucial M4 I managed to salvage from my friend's house
Thanks for all your input.
Small cases offer looks and space. After that you limit yourself in every other way. Length of GPU*, additional drives, tall cpu heat sinks, sizes of radiators, and expansion slots. Depending on the case cooling can also be an issue. Small space with hot components and limited fan mounting points*.
*depending on case.
I see someone has been on OCN recently, Mr. Hagame1015 ;)
Unless you're running two or more GPU's and/or more than 2HDD's, then I don't see the point in huge cases. The way advertising makes out PC gaming, you need the biggest and best of everything just to run solitaire, these days.
I'd get more RAM, though.
