My coworker brought this up and I did some research on the topic. I cant seem to find any good software. My intended use would be 1-20 amps and not more than 15 volts or so. I plan to have two test leads. I believe I can make the hardware, but essentially I am not sure how to set up a decent program to analyze data live with correct scaling, accuracy, etc, etc. I am not much of a software guru, please help!
A quick google brought me to this:
http://makezine.com/2007/11/24/turn-your-soundcard-into-an-os/
So, check out the two pieces of software listed there. However I would strongly recommend you get a cheap usb sound card for this (something like http://dx.com/p/usb-2-0-stereo-sound-card-adapter-129473 would probably be good enough). reason being is that you're far less likely to fry your whole PC and just the sound card if you use one of those. I would especially use one of those if your soundcard is embedded on your motherboard.
This sounds awesome i will have to try it!
Right on. Yeah basically I am going to build an USB modular device to plug into my laptop at work. (my day job is auto mechanic). I am going to put some restrictions into the inputs to limit the possibility of frying the sound card itself. I will probably build some type of hobby case or something not sure yet. Thank you for your advice, what I am really after is software. Goodness a real bench type scope is $500+.
Also, my coworker and I were experimenting with a small tablet as the i/0 to make some kind of portable variation. Anyone interested in coding new software???!!! Snap-On sells the Vantage for thousands of dollars, but I cant seem to understand the reason why besides proprietary reasons.
Oh and thank you speedfox for the link. If anyone has any ideas for a voltage diverter to lower the signal volts that would be great. It appears I may be going the linux route for this. I'm pondering a small raspberry pi type build with replaceable sound card, just in case. I am just so disappointed with prices of decent oscilliscopes.
No problem, but I'm wondering why one of the cheap handheld DSOs that are about now (like this: http://www.amazon.com/SainSmart-Pocket-Sized-Digital-Oscilloscope-DSO201/dp/B004Y3QHZ6) would not do the job?
