Home Workstation for Simulation Work
Hey first time poster looking to get some help on my build, thanks in advance for any advice or suggestions made.
I am trying to do what I can to keep costs down, but I don’t have any strict limitations. If I need it I will buy it. Also, it’s relevant I think that I will be building this myself (I don’t have a lot of experience doing that).
The components I have picked out so far:
Board+CPU: Supermicro AMD Motherboard/CPU Bundle - M12SWA-TF (TRP 3995wx)
CPU Cooler: Noctua NH-U14S TR4-SP3
GFX: GIGABYTE GeForce GT 1030
Memory: 8x256GB DDR4 3200 (PC4 25600)
SSD: Seagate FireCuda 530 M.2 2280 4TB with Heatsink
Power Supply: Seasonic PRIME TX-1000
Case: Fractal Design Meshify 2 XL Black
OS: Windows 11 PRO
Nas: RackStation RS3618xs??
There are no peripherals needed post setup as I don’t plan to use the computer directly but rather remotely connect to it. My preference is to make it as small as possible without making any compromises. I don’t care for how it looks really, it’ll just be in a corner somewhere doing it’s thing. That Noctua brown is pretty ugly though, if I end up with that I’m probably going to spray paint it black. Noise matters, it’s not crazy important, but I don’t want it being too loud. No RGB.
I aim to have this workstation to be running 24/7 at capacity. My normal set up is M1 16 Macbook Pro with external displays, but there are some applications I use that don’t jive well with that set up, even under parallels, so when I need to, I’ll be VPNing into the workstation to use Windows. Otherwise, it’ll be running simulations that I need to get work done. The simulations are CPU and memory intensive, but have basically no GFX requirements hence the cheap GFX card, just want something that can output dual 4k60hz if I need it to do that. The simulations can use upwards of 2TB of memory so my plan is to have double that for SSD space and transfer the completed files to a NAS Storage to be able to use and access the files there. I will need some additional space for everything I need when VPNing into the machine, the additional 2TB should easily cover that. I’ll be leaving the machine at my parents house as I travel remotely and they are not tech savvy, so building something super complicated that they may not be able to fix while on the phone with me is a relative consideration for me.
The questions I have:
  • I run a UNIFI UDMP+USW24P for my networking gear and I specifically chose this motherboard because it has 10GBE and its relative price point (I know it’s not as feature rich as some others but I don’t need them) and prioritizing my SSD choice to be able to transfer files quickly. The recommendation I got from a friend is that for my particular use case the file transfers can take awhile and so I want to make that as fast as I can. Right now I have chosen a desktop case that I think will work well, but I am considering buying a rackmount server chassis for both the workstation and NAS so that I can connect both of them directly, neatly, and cleanly to the networking equipment. But I don’t have any experience nor a good idea about how to to pick an appropriate chassis, let alone build one. Same goes for the NAS. Also, I’ve read that this results in a much noisier setup and that it is not as user friendly to build in. Is this is a good idea? If so, what should I get and what do I need to consider if building it that way. The only thing I really know so far is it probably needs to be 3-4U. It seems this would likely affect my cooling options and considerations as well but I am not sure exactly how. What do you think I should do? What size chassis should I get if I do?
  • Similar to the workstation chassis, I was looking at picking up a 1-2U rackmountable storage device from Synology. I can pick one out based on the specs, but any recommendations on other brands, or suggestions on what to get there would be helpful as well. I am still in the process of picking one out.
  • In regards to the cooling, I am strongly preferential to air cooling because if a problem occurs I believe this will be easier for my parents to handle then with an AIO liquid cooling solution and requires less maintenance longer term. I am also a bit concerned about potential damage to the system, especially since I am the one building it (not that I think it’s a major concern either). It’s possible I mess that up somehow given my lack of experience with building though. That’s why I picked the Noctua. However, I’ve also read that the fan has an orientation problem with this specific board+CPU configuration and also that, especially if overlocking, it might not be sufficient for this setup. And if building in the server chassis, I’m even less sure about it then. Do you think the Noctua + this case’s fans will be sufficient? Any suggestions/recommendations on changes/alternatives if not?
  • Does it make sense for me to make the effort to overclock this system or is it not worth the effort? I believe I’ve read that it’s not really suited for that somewhere. If it does, will the power supply be sufficient? I may in the future upgrade to a much more demanding GFX card and use the workstation directly or for other reasons and I want to plan for that in advance as well. Right now I believe it’s sufficient, but not if sure if I apply those additions. Is this correct and if not what would be sufficient wattage capacity? An efficient power supply is a priority since this thing will be loaded all the time. In conversation with Seasonic’s customer service they told me some 1600W Titanium PSUs should be coming out Q1-Q2 this year, but who knows with the supply shortages and right now 1000W is the best they have at titanium.
  • Is my SSD choice fairly optimal or should I consider another?
  • Similarly, if not going the rack mount route, is my case choice optimal or should I consider another? I know it’ll work, just not sure if it’s the best option. Also, should I consider upgrading the case fans? Not sure exactly how many and at what sizes if I did, but that is something that I can figure on my own, I just need to look into it, but if you know that would help too.
  • Lastly, perhaps 5995wx is coming out soon. I am trying to consider what upgrade paths will look like and how soon next generation hardware may be released and if it makes sense to delay a bit. Right now, it seems probably not but maybe I am wrong. Any thoughts?
  • Anything I miss?
I know this was long and I’ve asked a lot of questions, and again, thanks in advance for taking the time to read it and for any help or suggestions. I am looking to get this built as soon as possible, so eager to get it figured out and get to work building it.
Some of my thoughts of the Simulation itself:
Do you know how much of the simulation code will run in parallel versus how much is bottlenecked to a single thread— the answer to this my dictate you wanting a machine with fewer cores and faster threads.
How do you know you need 2TB of memory to complete a simulation? In my experience with FEA, if you need that much memory you are using the wrong solver setup.
Some of my thoughts on the hardware:
I’m pretty sure you can’t overclock threadripper pro so you shouldn’t have to worry too much about extra thermal headroom in your setup.
I’d stick to desktop cases unless you already have an existing rack you want to populate more, desktop case selection is much better than rackmount case selection.
I wouldn’t count on the 5995wx coming out being a given, AMD has been strange with what it is releasing lately (i.e. no 5950x3d), but if it does come out alot of people think it would be announced in march of this year.
The FireCuda 530 is a good choice for an ssd if you are going to be regularly writing a ton of data to it; it has about the highest write endurance of any non-enterprise class M.2 NVME.
I agree with you on air cooling, much less of a headache long term. If you go the desktop case route you should have less issues with cooler orientation because you can exhaust air out the top of the case; where as with a rackmount case the noctua would point at the side of the case where there are no vents.
The computation time scales with CPU speed. There is a function within that allows control for thread count. Based on what I know, this should be the best option.
The program has a feature to estimate the requirement needed to do the solve and several algorithms with which to do so. Even at 2TB, I have to cut corners in some cases to get it to fit. I can make them far larger than that too. And this is still the case even after it’s recent update where it cut the requirements down quite a bit. Even with this CPU, there are time considerations that necessitate simplification as well. It could be argued that there are better ways to get the solutions at much less cost in both time and hardware, that the software could be done differently or better, but this is the current best solution available to me. I have to work with it.
Needless to say, I did not purchase it carelessly as it was quite expensive. I am sure.
That is my understanding as well, figured I’d ask just to double check.
I agree, it does seem like that is very much the case (no pun intended). I have a rack mount solution for the networking equipment, so that part is not the issue. It’s more a question of does it make long term sense to consolidate it this way.
Yes, and it was released OEM only at first and not individually to consumers until much later. It’s not a guarantee for it be offered non OEM this go around either. More importantly, I need this sooner than later, so I think it makes the most sense to not wait. I can tolerate something like 2 months, but that’s pushing it.
Exactly. Cool, I guess that part is considered done then.
It seems like the Noctua should work, but I’ve read several anecdotal reports that it was insufficient, but then again also some that say it’s fine. Given I plan to keep this thing loaded very regularly, I feel a bit of concern that if it’s a depends on your use case sort of thing, that I will fall under the former. Maybe I’m just overthinking it.
What about the case fans, do you think I need to make an effort to upgrade them or will the defaults be sufficient?
This is a very apples to oranges comparison, but I have a machine with dual e5-2697a v4 cpus running full tilt 24/7 on simulation work using NH-U12DX i4’s and the fans run at <900 RPM and temps are good. that’s about the same heat output as a 3995wx spread across two smaller coolers with very good affect. Worse case scenario you might need to change out the CPU cooler fan to something faster, like a NF-A15 HS-PWM.
I’d grab 3-4 120/140mm fans to add to the case, it has a ton a fan mounts in it and only a few fans come with it.
One other hit against rack mounted cases is that they typically don’t have dust filters on them, which are very useful in residential settings as long as they get cleaned as needed.
A little confused on the NF-A15 HS-PWM switch recommendation, I thought that’s what it comes with already. Could you clarify?
Yea, seems like lots of recommendations against the rack mount at this point and adding the fans seems to be the in between compromise.
Thanks for the reply.
The NH-U14S TR4-SP3 “only” comes with a NF-A15 PWM fan, the NF-A15 HS-PWM is a more performant fan that will fit the NH-U14S and improve cooling… although I suppose you could just run dual fans on the cooler to improve performance too, assuming you even need to.
Ah, okay, I got you now. I didn’t notice the HS part. Makes sense. Thanks for the tip.
Maybe TWO NF-A15 HS-PWM?? :grinning:
Edit: FYI, I talked to support over at Noctua to get their thoughts on this and although the names of the fan differ and do seem to imply one is a higher performance than the other, they are actually identical.
I think your right, according to the reddit the fan that comes stock on the cooler hits 1500 rpm despite what the fan specs on noctua’s site say.
Also did you see that the 5995wx ended up getting announced (or perhaps soft launched?) after all and it looks impressive.
