Thinking about upgrading the chassis for my home server to something more spacious inside.
The caveat is I also would like vertical GPU capability with 3 or 4 “slots” … as I would like to mount a pcie splitter to it, for additional add on cards. Oh, and throw in liquid cooling support too, for a 360mm AIO.
So looking for recommends on a chassis with these specs;
EATX motherboard support
Vertical GPU support, 3-4 slots, no case-mod required
Room for 8x internal 3.5" drives or
7x 5.25" external bays, without any sort of guide / rails that block installation of raid cages (this seems really hard)
Room for 360mm rad without losing drive bays
The motherboard is a Gigabyte x399, cpu cooled by a 360mm AIO. I’d like the eatx clearance mainly for all the sata cables coming off the thing.
These 2 are my recommendation. You can mount a 360 Rad in the midplane if you use just the 4 screw holes in the middle of the radiator. I’m unsure about tube length for AIOs, which could still be an issue
I have one of those! I didn’t think there’d be enough room but I will measure more closely.
Nowhere to mount the riser card / pcie splitter without modifying the case that I can see. That’s not a major issue though, once I put the lid on, I won’t see whatever ugly solution I come up with
I have basic non-swap cages already, and also SuperMicro ones with the backplane, but without a fast high static pressure fan, they’re hard to cool.
I also have some old full tower chassis that would work, if I took a dremel tool to the bays to remove supports that interfere with the sides of the cages.
I have my Lian-Li PC-6077. I wouldn’t change it for the world. So much storage space in a mid-tower ATX case. I don’t I think it supports EATX. EATX wasn’t a formalized spec when it came out.
For a desktop I use a 500D with 3 Icy dock 3.5+2.5 cages in the 5.25 slots in the front, as they are trayless hot-stappable sata cages, and it is handy haveing the extra drives available.
My next case will probably be a tray based 16- or 24 bay rack style chassis.
I use a 24 bad Norco knock off as a nas, and it works well.
The only thing it lacks is front I/O, but I can work around that.
Also the knock off nas I have only has 3x 120mm fans in the center, but I would fit a baffle, and run 6 PWM fans in a trio of push+pull pairs
I would probably go 4U again for next desktop case, but a longer/deeper case, because short depths don;t allow me enough room to rouse all cables etc…
