Hi there, I would like to say thanks in advance for reading this.
So... I am planning to make a server in a different room. I plan to have one of the units to be my gaming PC. I want to run as few as cables as possible. I know you can extend a USB devices through one cable via a hub. But I would also like to do the same thing for my display from my GPU. I heard you can do this with thunderbolt, I have tried some searching, but no luck. With newer devices using thunderbolt via USB C; I was wondering what device(s) would I need to get one (maybe two) display(s) and three to six USBs (maybe ethernet too).
(I don't want my room to look like this, lol)
Update 2/4: This is going to be more of a blog style post with updates every so often.
Anywhere between 25 and 100 feet (~8-30 meters). Thinking about Thunderbolt (some variation, not sure yet). If my idea works, I should have only one cable across the area.
I know I could do a wireless solution, but I don't want the latency with it. If stuff doesn't go the way I want I may do most wireless with one wire for the display.
The difference between 10, 15, or 30 meters makes a really big difference in the price and options available. Could you measure and narrow down the range?
