Maybe I will hot rod it and cut a hole in the top . Thanks for all the feedback though
If you do, please post pics. I wanna see that.
Go usb for ODD
Throw them on a shelf easier for finding case
External ODD master race
It works, and I can be sure the accuraterip database has the offsets.
oh damn, yeah. Those are thicc.
They get the job done tho.
Loving that yubikey with C → A adapter.
I’m a fan of the fractal meshify 2 compact
It doesn’t have a 5.25 bay but a usb to sata adapter and some velcro tape is all you really need
Or just a usb dvd drive
I was going to say Rosewill also
Phanteks / Fractal have game, with the dumb tier drive count support [+ 5.25 bay(s)], tower-wise.
http://www.phanteks.com/Enthoo-Pro.html
With the Define 7 / XLs, you’ll need to buy additional brackets, for accommodating somee additional hard drives [typically sold in pairs]. 7 has a single 5.25 bay, whereas the XL has two (2). Look at their manuals ahead of time, for drive / system arrangement idears
