Dear reader,
I am dealing with a home networking issue that is beyond my level of knowledge and capabilities. Which is quite low when it comes to networking, so please bear that in mind.
TL;DR
Network layout of three daisy chained routers has connection dropout issues on the main router (second in chain). Has worked for ±3 years without issues in current configuration, suddenly starts to cut out connection when it has to handle light to moderate bandwidth(?)/workload. Problem seems to be a conflict caused by one of the three routers. Cannot connect to router GUI during this issue. Rebooting this router (not resetting) solves the issue (takes ±5min to reconnect). Issue cannot be identified (on-board GUI diagnostics do not help much). Happens frequently, but without a pattern.
Setup and background
My home internet access is comprised of three routers on three levels of the house:
- One Cisco EPC3928AD; ISP box and primarily acts as throughput to Asus; ground floor; DCHP enabled; IP XXX.XXX.XXX.1
- One Asus RT-AC87U; installed for increased Wifi range; main connection device (nearly everything has been set to auto-connect to that); middle level; DHCP enabled; IP XXX.XXX.1.1
- One Sitecom WLR-3100 V2 003 (X3 N300); mainly acts as LAN splitter for top level (2 PCs); GUI indicates “AP” mode but DHCP and Auto-IP are enabled; IP XXX.XXX.0.1
Please note that this (concrete walled and floored) house has no LAN infrastructure / cables running throughout it, hence the many routers.
All run in standard setup, meaning DHCP and all other stuff is on auto / enabled (the network layman out-of-the-box setting). Often called ‘Wireless router’ or something.
More info can be provided on request, for the sake of conciseness and not knowing what to provide, I will try to keep it short.
No new devices have been added, no changes have been made.
There are three permanent LAN devices (PCs), a few nearly-permanent WiFi devices (tablets, two phones) and a few intermittent WiFi devices (laptops, old PCs, my primary phone) ranging from few times a day to few times a year (old PC).
Speeds are (using Ookla):
WiFi of Cisco: ±69down / ±30up @ 17ms
Wired of Cisco: ±95down / ±31up @ 9ms
WiFi of Asus: ±298down / ±30up @ 18ms
Wired of Asus: ±95down / ±31up @ 10ms
WiFi of Sitecom: ±79down / ±30up @ 16ms
Wired of Sitecom: ±87down / ±up Unable - just disconnects and reboot is required @ 10ms
?why the high down with the Asus Wifi, but not the wired directly at Cisco? ISP package claims 300Mbit/s, which is only true for the Asus router via WiFi?
Problem
The first occurance is unknown, as I was on holiday. I noticed the day I returned. The router was not disconnected from power and internet. I cannot detect any auto-update of firmware or something during that time of absence.
Problem seems to be a conflict caused by one of the three routers. Cannot connect to router GUI during this issue. Rebooting this router (not resetting) solves the issue (takes ±5min to reconnect). Issue cannot be identified (mobile application GUI diagnostics do not help much). Happens frequently, but without a pattern. It can be instigated by simply starting to watch a YouTube video on one PC, while the other PC is already streaming some VOD (TV via internet for example). It could drop out at the beginning of that video (after 2 min or so) or midway (after 15min or so). The Asus router GUI cannot be reached when it is having this issue.
It seems the issue is the Asus router. I cannot, however, figure out why. Also, why this occurs only after ±3years.
Unrelated but annoying additional problem
The Sitecom router also just cuts out connection with light to medium bandwidth usage, but always with massive usage. This has always been an issue since about 5 years ago up till now (just drops out when doing wired down/up speed test), hence the reason why the Asus has been purchased to replace it on the middle level of the house. A simple unplug-plug reboot solves this. It does not restore connection on its own. The router GUI cannot be reached when it is having this issue. Not so much a problem when it just acts as top level switch, but it is when I have to replace the Asus router with the Sitecom and 5+ devices are connected to it as main internet access point.
What I’ve tried
- Running GUI network diagnostics via Asus mobile application–> only points out that “there is no connection to the internet” (order is: your device>Asus router>modem>internet).
- Removing Asus from chain, replaced by Sitecom (so no top level anymore, only 2 chained) → issue does not occur
- Disabling DHCP on Asus → no internet access for connected devices / could not get to router GUI anymore(?)
- Trying to learn how to set up daisy chained routers, but most guidelines did not help me trying to figure it out, as at most DHCP steps I could not figure out what settings to change (wording and options is different to most GUI of the guideline routers)
- This includes changing the IP of the Asus from X.1 to X.2, but I was unable to connect to it after I did that, so I had to reset the Asus again.
- Reserving the first X.1 till X.10 on the Cisco router
- Reserving the first X.1 till X.10 on the Asus router
- Factory reset (reset button) on Asus; Cisco; Sitecom (does not include firmware reset).
- Updating the Asus firmware (current 3.0.0.4.382_50010-gb0c6a12) → gives error “The router cannot connect to ASUS server to check for the firmware update. After reconnecting to the Internet, go back to this page and click Check to check for the latest firmware updates.” While I am connected.
- Running StarTrinity, but this only indicates the dropout time, not the cause of course.
- Scanning the syslog file of the Asus router, but I cannot identify any obvious errors. One thing I did find was that it went from log entry date July 31st [current time] to Febuary 14th [01.00 time] to August 01st [current time] at some point, mutiple times. This was during one of the dropouts, but I cannot say with pinpoint accuracy as not all uptime log entries are included in this syslog.
- There seem to be no IP conflicts, as every router has different IP adresses and IPs assigned to their devices. But this might not be true, as my knowledge on this is not that good.
Things I have not tried
- Setting the Asus router to AP mode
- Disabling any DHCP setting on the primary router (Cisco)
- Disabling any DHCP setting on the tertiary router (Sitecom)
- Much more I don’t know about
I suspect there is some conflict involving the IPs / DHCP settings, but I’m not sure. Then again, it also seems to be related to workload. Also, why would this have worked for ±years and now suddenly fail?
- Are there any obvious faults or setup issues?
- Are there any diagnostic steps or programs I can run in the background to log untill the issue occurs?
- Are there any other things I can try to solve?
This is not ideal in a work-from-home environment.
Thank you in advance.
Kind regards,
JB
