Hey Syndicate Peeps !,
So it is time for me to finally build the home NAS. I originally had musings of using one of the many Rpi I have floating around, but since thought better of it.
I went for second hand AMD hardware and purchased a FM2 mobo that supports DDR3. My question is in two parts
Hardware:
More specifically HDDs. All vendors are now selling NAS drives made for small consumer setups with "special features" but vague on details. In Australia these are between $45 to $60 per more expensive than normal drives e.g WD blue vs WD Red. How much better are in real terms?. Is it just marketing placebo to make me feel safer ?
Given that files system either BTRFS/ZFS is handling redundancy in Raid 5 or 6 is it worth it Or should buy another normal drive with the money saved and add some capacity and provide better redundancy.
File-systems:
I am deciding between ZFS and BTRFS. At the moment I like the BTRFS's ability to add drives to your pool dynamically and I think that it is stable enough to use. But I haven't had any experience in using it or what bugs/things to look out for. What is be a good amount of the RAM to install to support the filesystem is it as much as 1gig per TB ? or is it a leaner beast.
ZFS looks cool, I have wanted to play with it for ages and also experience FreeNAS. But I think that it is fairly inflexible and requires significant system resources. But happy to be convinced otherwise, or maybe there are features I haven't consider.
Thanks in Advance
