Hey guys!
Planning on getting some headphones. I’m looking at the XPT100’s (basically the same but cheaper than the HM5’s and black… :P).
Was wondering if anyone has any experience with the HM5’s/XPT100’s.
What did you like about them?
Were they comfortable (w/ or w/o glasses)?
What didn’t you like about them?
And if you didn’t like them at all, what would you suggest?
I’ll be using these mostly on the go. So, comfort and relatively good sound isolation is required.
I know they are BIG… And I’m fine with that… I’m also trying to stay around the $100 range…
Thanks!
http://www.amazon.com/NVX-Over-Ear-Headphones-ComfortMax-Cushions/dp/B0093PVTPS
