hey guys
i'm building a pc and i need to know the dimensions of the his radeon 7870 iceq and not
or if they fit in the zalman z9 plus chassis
hey guys
i have a HiS 7870 GHZ fan edition, i will look for the demensions in a minute.
11.69" x 5.5" x 1.73"
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404&Tpk=7870%20iceq
Dimensions of the GHZ fan editions are: 34mm x 256mm x 127mm.
And yes they will probably fit without any problem.
does any one know what the gigabyte radeon 7870's dimensions are
Look it up at Newegg, its all there.
