Hi guys, so I've been noodling over NewEgg and Amazon for a monitor upgrade. I currently have a 32" 1080p 3DTV @60Hz and about an 8ms response time. It's pretty decent and the image quality is great.
However, what I want is very fluid gameplay.
I do not want to compromise in size, so 24" is out of the question. What I need is a 27" monitor.
So here's what I'm asking, When it comes to fluidity, what is better, higher refresh rate, or lower response times?
I have seen many gaming 27" monitors that have a low response time of 5ms, 2ms, and 1ms. However they are IPS panels, and although I know that IPS is great for color reproduction I hear that's it's generally slow for refresh rates/fluidity.
The ones with a higher refresh rate are generally more expensive and I was looking for a 120hz monitor but it seems they're being replaced by 144hz monitors as I can't find many anymore.
One last thing. I want to stay at 1080p
My budget is $200 - $300. MAYBE up to $350, but ABSOLUTELY no more than that, with tax and everything.
Here are some of the monitors I was considering:
http://www.amazon.com/MX279H-27-Inch-Screen-LED-Lit-Monitor/dp/B00B17C5KO/ref=sr_1_2?ie=UTF8&qid=1415988252&sr=8-2&keywords=27+inch+monitor
http://www.amazon.com/AOC-e2752She-Response-Earphone-Resolution/dp/B00CMKOVPQ/ref=sr_1_7?ie=UTF8&qid=1415988252&sr=8-7&keywords=27+inch+monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014378
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001913
http://www.amazon.com/VS278Q-P-Ultrafast-27-Inch-LED-Lit-Monitor/dp/B009HNEBLK/ref=sr_1_1?ie=UTF8&qid=1415988938&sr=8-1&keywords=27+inch+monitor+120hz
