I am have having a weird issue where the ping on ac devices is incredibility high especially when compared to n devices on the network.
For example, below is from my main computer which uses an Intel 7260 ac wireless card:
PING enyo.network.dev (192.168.2.5): 56 data bytes
64 bytes from 192.168.2.5: icmp_seq=0 ttl=64 time=0.824 ms
64 bytes from 192.168.2.5: icmp_seq=1 ttl=64 time=85.663 ms
64 bytes from 192.168.2.5: icmp_seq=2 ttl=64 time=96.012 ms
64 bytes from 192.168.2.5: icmp_seq=3 ttl=64 time=105.124 ms
64 bytes from 192.168.2.5: icmp_seq=4 ttl=64 time=37.823 ms
64 bytes from 192.168.2.5: icmp_seq=5 ttl=64 time=134.227 ms
64 bytes from 192.168.2.5: icmp_seq=6 ttl=64 time=342.808 ms
64 bytes from 192.168.2.5: icmp_seq=7 ttl=64 time=262.857 ms
64 bytes from 192.168.2.5: icmp_seq=8 ttl=64 time=101.188 ms
64 bytes from 192.168.2.5: icmp_seq=9 ttl=64 time=88.511 ms
--- enyo.network.dev ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.824/125.504/342.808/97.071 ms
And this is from my phone which also uses 802.11/ac:
PING 192.168.2.7 (192.168.2.7): 56 data bytes
64 bytes from 192.168.2.7: icmp_seq=0 ttl=64 time=83.417 ms
64 bytes from 192.168.2.7: icmp_seq=1 ttl=64 time=51.472 ms
64 bytes from 192.168.2.7: icmp_seq=2 ttl=64 time=13.581 ms
64 bytes from 192.168.2.7: icmp_seq=3 ttl=64 time=10.373 ms
64 bytes from 192.168.2.7: icmp_seq=4 ttl=64 time=10.304 ms
64 bytes from 192.168.2.7: icmp_seq=5 ttl=64 time=17.725 ms
64 bytes from 192.168.2.7: icmp_seq=6 ttl=64 time=29.085 ms
64 bytes from 192.168.2.7: icmp_seq=7 ttl=64 time=40.047 ms
64 bytes from 192.168.2.7: icmp_seq=8 ttl=64 time=42.426 ms
64 bytes from 192.168.2.7: icmp_seq=9 ttl=64 time=51.390 ms
--- 192.168.2.7 ping statistics ---
round-trip min/avg/max/stddev = 10.304/34.982/83.417/22.301 ms
As you can see the ping is quite high and should be much lower, for comparison below are some ping stats from n devices on the network.
This is from my mothers computer which uses 802.11/n on the 5GHz band:
PING 192.168.2.36 (192.168.2.36): 56 data bytes
64 bytes from 192.168.2.36: icmp_seq=0 ttl=128 time=0.817 ms
64 bytes from 192.168.2.36: icmp_seq=1 ttl=128 time=0.857 ms
64 bytes from 192.168.2.36: icmp_seq=2 ttl=128 time=0.873 ms
64 bytes from 192.168.2.36: icmp_seq=3 ttl=128 time=0.755 ms
64 bytes from 192.168.2.36: icmp_seq=4 ttl=128 time=0.793 ms
64 bytes from 192.168.2.36: icmp_seq=5 ttl=128 time=0.841 ms
64 bytes from 192.168.2.36: icmp_seq=6 ttl=128 time=0.891 ms
64 bytes from 192.168.2.36: icmp_seq=7 ttl=128 time=0.764 ms
64 bytes from 192.168.2.36: icmp_seq=8 ttl=128 time=0.828 ms
64 bytes from 192.168.2.36: icmp_seq=9 ttl=128 time=0.840 ms
--- 192.168.2.36 ping statistics ---
round-trip min/avg/max/stddev = 0.755/0.826/0.891/0.042 ms
And this is from one of my servers which uses 802.11/n but on the 2.4Gz band:
PING drake.network.dev (192.168.2.6): 56 data bytes
64 bytes from 192.168.2.6: icmp_seq=0 ttl=64 time=1.799 ms
64 bytes from 192.168.2.6: icmp_seq=1 ttl=64 time=1.910 ms
64 bytes from 192.168.2.6: icmp_seq=2 ttl=64 time=1.802 ms
64 bytes from 192.168.2.6: icmp_seq=3 ttl=64 time=1.858 ms
64 bytes from 192.168.2.6: icmp_seq=4 ttl=64 time=1.734 ms
64 bytes from 192.168.2.6: icmp_seq=5 ttl=64 time=1.726 ms
64 bytes from 192.168.2.6: icmp_seq=6 ttl=64 time=1.820 ms
64 bytes from 192.168.2.6: icmp_seq=7 ttl=64 time=1.835 ms
64 bytes from 192.168.2.6: icmp_seq=8 ttl=64 time=1.789 ms
64 bytes from 192.168.2.6: icmp_seq=9 ttl=64 time=1.844 ms
--- drake.network.dev ping statistics ---
round-trip min/avg/max/stddev = 1.726/1.812/1.910/0.053 ms
The access point I am using is the Unifi AC AP LITE and it is connected directly to my pfSense box which I used to record all the ping data for these tests to keep things mostly consistent. I am at a complete loss as to what could be causing these issues and would appreciate any help in solving them.
