Hello everyone, I have a bit of a issue that has been bothering me very much. I have a Higher end system and i can max any game ive come across. I have gotten into Fallout 3 because of the awesome mods they have for the game but for some reason or another my frame rate is 15-20fps (unplayable for some) I have tried many things to fix this without any solution.
dude, I've almost given up on fallout. Don't worry, it's not your computer. Fallout is just a really patchy coded game. Mine microstutters and locks up every few minutes. Tried may .ini file edits. It's ridiculous.
Im determined to play fallout, Im so close to the solution. I installed new drivers for the audio and changed the quality to 16bit CD on the sound. It helped alot (now at 25-30fps) but thats still lower than what i know my computer can handle. I seen somewhere that ALchemy is recommened but i cant find the latest version anywhere to download... gerrrrr
Try moving the benableaudio=0 around in the .ini file. It may have something to do with the priority of process. Other than that, windows xp compatibility mode. That's the one thing I haven't tried and I'm reluctant too.
We also both have eyefinity/windows duel displays enabled. Disabling a monitor while playing may either fix the problem or at the bare minimum increase frame rate
ummmm, maybe the 5.1 speaker system too. Try to disable it to 2.0 in your realtek audio controller. The game may not be made to be decoded into 5.1. These all really are shots in the dark as well. I'm just looking at possible connections.
I did mess around with the speaker setup, I changed it to 2.0. I plugged in a older USB headset that i had around and ran the sound through that and it solved the issue. I will try moving the line around in the .ini and disabling a screen. Thanks for your help bro.
