Hello I am new to VFIO but not new to Linux. First I will post Specs then Configs/Logs
Things I’ve tried:
Pinned CPUs cores 2-7
Used isolcpus
Recompiled Manjaro Kernel with VFIO patches
Installed VirtIO drivers for all devices and Device Manager
Used MSI v2 tool to enable MSI for GPU and GPU Audio
OS:Manjaro
Kernel: Personally Compiled 5.6.11-1 with VFIO Patches.
Specs:
Gigabyte Z390 AORUS Motherboard
i7-9700KF 5.0GHz @1.35V (NOT multithreaded)
EVGA 2080 Super XC HYBRID (Passed to VM)
GT 210 ( Arch Linux Host)
EVGA 650W Gold+ PSU
VM XML:
<domain type="kvm">
<name>win10</name>
<uuid>26314a1c-8d6c-4639-b296-2dde5ef4377b</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">12386304</memory>
<currentMemory unit="KiB">12386304</currentMemory>
<memoryBacking>
<hugepages/>
</memoryBacking>
<vcpu placement="static" current="6">36</vcpu>
<iothreads>1</iothreads>
<cputune>
<vcpupin vcpu="0" cpuset="1"/>
<vcpupin vcpu="1" cpuset="5"/>
<vcpupin vcpu="2" cpuset="2"/>
<vcpupin vcpu="3" cpuset="6"/>
<vcpupin vcpu="4" cpuset="3"/>
<vcpupin vcpu="5" cpuset="7"/>
<emulatorpin cpuset="0,4"/>
</cputune>
<os>
<type arch="x86_64" machine="pc-q35-4.2">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
<bootmenu enable="yes"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="anything"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="none">
<topology sockets="1" cores="6" threads="6"/>
<feature policy="require" name="invtsc"/>
<feature policy="require" name="topoext"/>
</cpu>
<clock offset="utc">
<timer name="tsc" present="yes" mode="native"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/ech0/Downloads/Microsoft_Windows_10_Enterprise_Version_1903_X64-CYGiSO/cyg-w1903x64en.iso"/>
<target dev="sda" bus="sata"/>
<readonly/>
<boot order="1"/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<source file="/home/ech0/Downloads/virtio-win-0.1.171.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/win10.qcow2"/>
<target dev="vda" bus="virtio"/>
<boot order="2"/>
<address type="pci" domain="0x0000" bus="0x0b" slot="0x00" function="0x0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x16"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0x17"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x18"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="10" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="11" model="pcie-root-port">
<target chassis="11" port="0x19"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<controller type="scsi" index="0" model="virtio-scsi">
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</controller>
<controller type="scsi" index="1" model="virtio-scsi">
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</controller>
<interface type="network">
<mac address="52:54:00:bd:69:df"/>
<source network="br1"/>
<model type="virtio"/>
<link state="up"/>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<input type="tablet" bus="usb">
<address type="usb" bus="0" port="1"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<graphics type="spice" autoport="yes">
<listen type="address"/>
<image compression="off"/>
<gl enable="no"/>
</graphics>
<video>
<model type="qxl" ram="65536" vram="65536" vgamem="16384" heads="1" primary="yes"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
</video>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x046d"/>
<product id="0xc539"/>
</source>
<address type="usb" bus="0" port="2"/>
</hostdev>
<source>
<vendor id="0x0b05"/>
<product id="0x184d"/>
</source>
<address type="usb" bus="0" port="3"/>
</hostdev>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<vendor id="0x1852"/>
<product id="0x7022"/>
</source>
<address type="usb" bus="0" port="4"/>
</hostdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
Grub Boot Line
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_iommu=on iommu=pt isolcpus=2-7 nohz_full=2-7 rcu_nocbs=2-7 transparent_hugepage=never rd.driver.pre=vfio-pci vfio-pci.ids=10de:1e81,10de:10f8 pcie_acs_override=downstream,mul>
Passed Through Devices:
2080 Super
Nvidia HD Audio Controller (GPU Audio)
Logitech Wireless Pro
YROCOM C&C Co., LTD DigiHug USB Audio (Fii) Olypus 2 AMP + HD6xx headphones)
I’ve tried Plugging the USB DAC for my headset into the dedicated USB-DAC port on my Mobo as well as a standard USB-3.0 port
