High CPU utilisation with gluetun/wireguard and qbittorrent
Hi frens,
I just moved my torrent setup into docker containers and I am facing real high cpu utilisation while downloading. Way higher then when I used wireguard and rtorrent natively on my host.
my settings look like this:
version: "3"
services:
  gluetun:
    image: qmcgaw/gluetun
    cap_add:
      - NET_ADMIN
    networks:
      mvl-200:
        ipv4_address: 10.60.1.5
    ports:
      - 41870:41870
      - 41870:41870/udp
      - 80:80
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - WIREGUARD_PRIVATE_KEY=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
      - WIREGUARD_PRESHARED_KEY=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
      - WIREGUARD_ADDRESSES=xxxxxxxxxxxxxxxxxxxxxx
      - SERVER_COUNTRIES=Netherlands
      - FIREWALL_VPN_INPUT_PORTS=xxxxxxxxxxx
    volumes:
      - /media/glueton:/gluetun
 qbittorrent:
      image: linuxserver/qbittorrent
      container_name: qbittorrent
      network_mode: service:gluetun
      environment:
        - PUID=1000
        - PGID=1000
        - TZ=Europe/Berlin
        - WEBUI_PORT=80
        - UMASK_SET=022
      volumes:
        - /media/qbittorent/config:/config
        - /media/moenas/media/Downloads:/downloads
      depends_on:
        - gluetun
      restart: always
networks:
  mvl-200:
Any Ideas? It cannot be that qbittorent is that inefficient… Does wireguard need some specific settings which I might have overlooked?
qdm12/gluetun
Supports Wireguard both kernelspace and userspace
I would attempt to verify if the image is using kernel mode wireguard or userspace wireguard - the latter could easily explain heavy cpu usage.
Also check top while the machine is busy, this should show you the busy process. Hit “c” to show full commands.
I found an error with the linuxserver/qbittorent image and changed to another image, which solved the problem
Cheers
What was the error in the image? I am encountering the same issue?
sorry for being late but I cannot remember what exactly the problem was… I switched to
image: Package qbittorrent · GitHub
which resolved the problem. there also has been some updates to qbt so your problem might already be resolved.
You can deleted unwanted stuff to lower the CPU utilization.
