Hiding certain removable media devices
So I have a PCIE to Sata 6Gb/s adapter card in my PC, and it always shows the option to eject my SSD which is plugged into the adapter card. How can I disable/hide it so that Windows wont show me the option to eject my SSD? Its been bothering me a lot recently because sometimes I accidentally click "eject Kingstone. . . . etc" and then I have to restart for my PC so that I can access my SSD again. I also have the same problem with a usb wifi adapter.
Hopefully someone understood what I want to do, and can help me because I have no clue how to do it, and google searches didn't seem to help.
Help? Is this even possible?
I think you should just be able to hit the arrow next to the notifications click customize and one of the options should be the safley remove hardware which you can disable assuming your on windows 7 and I think it works on 8 to
lol i know how to safely remove the device, what I want to do is hide the option to remove a certain device. For example, my SSD gives me the option to safely remove it. I want to disable/hide that option, but im not sure if thats possible.
ok no I was talking about this:
not this:
