This post is my last effort to try to switch to Linux. Sadly due to my mental illness I am a heavy distrohopper. I can’t be satisfied with a distro. Every distro has an issue with me. For example. Mx Linux uses xfce, Fedora unknown cli to me, solus is good but my boyfriend hates it, pclinuxos unknown, antix unknown, I got harrased for using Arcolinux, parrot unknown, kali is for hacking, lite uses xfce, puppy is for low end, peppermint also. Arch installation to hard, manjaro is good but I already used it, Ubuntu is also being hated, Debian no proprietary software. See? I can’t stick with a distro. I can’t create that bond with it. Please help me.
What about making your own distro? I’ve never done that but sinc you’re not satisfied with anything that’s around you can use the pieces of some distros that you like and create your own. There are many tools available online to help you out with this process.
You want me to use a unsupported distro? A Linux newbie like me.
What are you doing with your computer mainly? What do you need it to do for you?
I’m asking because:
I used to be a distro hopper, until I learned how linux and distros work. That perfection doesn’t exist. That I myself am not perfect and that it doesn’t matter that a distro isn’t perfect.
I just changed the things I had some problems with to better suite me and got on with what I really wanted to do, wrote the software and made the things I really wanted to.
I began with Ubuntu, had issues with the packaging system and slower development pace. Went to Fedora had some issue with that, tried Mint, learned more about systems, and then about 8 years ago settled on Arch.
I no longer care about the opinions of others regarding distros unless it’s about a very important security/code problem/fault. The reason I don’t care? They’re all essentially the same underneath and can be modified to my use case and my use case is different to everybody else’s use case.
So that’s my experience, perhaps that gives some insight towards your experience as well.
Gaming. I want to game. I want to run most of my favorites like xplane 11, skyrim, enderal. ets2’s map editor which is windows only. Also. I have social anxiety so the distro can’t be Ubuntu or Arcolinux since I got called a mentally ill person for using them.
I know it is not this easy but frankly other peoples opinions don’t matter on that. If they happen to be the best for the task than that is all that matters.
Putting aside others opinions,
What are some of your most and least favourite distro’s so far?
Which ones have you used the most, what did you like, what didn’t you like? Around which ones did you find a supportive community especially?
I want your opinions on this, here to help.
Pop!OS is a Steam-friendly distro.
Since this is topic nr… gazillion you create about this again.
If you can’t stick with a single distro, then likely not use Linux?
In the end all distro’s are Linux, and are similar in their core, depending on used kernel.
The main differences are the package management systems,
and which DE you prefer to use.
If you prefer to stick in a Unix / Linux type of eco sytem, then you might wanne try out bsd.
If you want one of the most stable distributions around, that isn’t the same,
as the ones you listed?
Then try Open Suse.
The longest I’ve used a distro was Manjaro KDE for 3 weeks. But I had to leave due to audio issues with KDE.
What particular audio issues did you have? Was it around pulseaudio or the KDE audio panel not letting you configure something the right way?
What distro didn’t have that issue for you? Perhaps it’s something that could have been fixed, or can be carried forward to the manjaro/KDE devs with some community help here
EDIT: If you get distro/linux/kde/audio issues @me or DM me, you can be as awkward as you want with me, I don’t mind, I’m here to help the community.
Though I’m not always around as often as I like to be.
for purely gaming, i would suggest Manjaro or PopOS!
And audio issues can happen to all of us, its just a matter of resolving them, that makes for a good learning experience.
And if the longest you`ve had a distro, is 3 weeks, that nearly not enough time to learn how to customise it like you want.
Key point to using Linux (as it stands now), is to learn how it works, and how you can make it do what you want
I would select my headphones but in certain game it would revert to internal speakers which don’t exist.
What computer and audio setup do you have?
I presume you’re plugging your headphones into the front panel jacks on a desktop PC?
My best guess is that the jack detection (checks if headphones are plugged in) isn’t fully working.
USB headphones with 7.1 surround the headphones work with all other de
Ok that makes sense why that would happen.
Lots of distros don’t properly save USB audio devices as the default device and revert to the internal sound on the mainboard instead.
Especially when the internal sound module gets loaded before the USB sound module is.
If you have pavucontrol installed or even the standard pulseaudio panel, can you show me a screenshot of that when it happens and post the output of pactl list sinks from the terminal?
I’m currently on windows 10.
Well then KDE doesn’t seem the perfect DE for you then i guess.
Like i mentioned above maybe Open Suse might be something for you.
In my opinion as far as KDE is concerned Open Suse has kinda one of its finest implementations of it.
However of course there are also other DE’s to choose from.
In the end Linux is just Linux!
No. I want to use KDE because it’s the closest I can get to a windows 10 look https://www.reddit.com/r/unixporn/comments/cftroh/kde_plasma10_updates/?utm_medium=android_app&utm_source=share
Why not stick with Windows10 then?
If you simply want to stick with the Windows type environment.
Linux simply cannot offer you a perfect Windows10 replacement experience.
In the end you can tweak any DE to look like Windows10.
However the eco system between Linux and Windows is just simply different.
All the hardware support from manufacturers are simply targeted at the Windows platform.
This will always be a chicken and egg problem.
Hardware support on Linux is there, but generally pretty generic.
