Hi I am building my first custom gaming pc and i am using a Intel 3rd Generation Core i5-3570K CPU and i need a motherboard that has 2 pci slots that will fit 2 EVGA Nvidia Geforce GTX 660's on it,im pretty sure it is pci-e 3 but im not sure. any ideas? and i need it to be relatively cheap because i am on a budget, please help? thanks
Why 2 660s? Why not one 670? Do you have a budget in mind?
my budget is around $600
You dont need pci-e 3 no card fully takes all the bandwith from pci-e 2 yet.
What are the parts your looking for becase $600 is a lot for just a motherboard
No, $600 is around the budget i want for the whole build, and im using a EVGA GeForce GTX 660, Intel Core i5-3570K , can i overclock a 3570K ? and thats all i have so far, i need a motherboard that has 2 slots that are for the GeForce GTX 660, it says the card is PCI-Express 3.0(x16)
intel "k" chips are unlocked chips for overclocking
so you allready have 1x cpu 1x case 1xhard drive 1x660 1x cd/dvd drive so your looking for x1 gtx 660 1x psu and x1 motherboard that is capable of sli in pci e x 16 for $600?
no i dont have a case,ram, hdd, psu, or a cd/dvd drive, but yea im looking for a motherboard that has 2 pci express 3.0 x16
i chose a gigsbyte motherboard. would this work? is there any flaws? please help http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2276156&sku=G452-2363
