Hi all, i need some help :)
So im building my first machine, ive so far got a 8350 in there but i am deciding on my graphics card.
Its mostly between these two, also if you dont think either of these are good please feel free to recomend another.
Thanks a bunch.
Andrew.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2546187&CatId=7387
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2318242&CatId=7387
I'm confused, what universe do you live in where a 7870 is cheaper than a 7850? If you can get a sapphire 7870 for a similar price, go for that instead.
those are on sale rignt now on newegg for signifivantly less
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150609
id spend 10 more and get the 7870
so 7870 is better i take it ? =p lol this is my first build so im still just shoving your guys's knowlegde in ma brain =p
would this asus 7870 be nicer ? http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121649&Tpk=7870&IsVirtualParent=1
generally, when it comes to GPU's, larger numbers in the name=better
Yes!
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814202025 or something like this.... haha sorry for the questions.. im just like a kid in a candy shop =p
question; is the asus one really worth $50 more?
Asus>sapphire>gigabyte>xfx>powercolor
Nope.
xfx it is (for me atleast)
ok awesome thanks alot guys!....
how do you guys think its coming so far ? http://pcpartpicker.com/p/QxyR
You can fit a 7970 in that budget.
http://pcpartpicker.com/user/armypig/saved/1t5J
Yeah, or if you like the industral look, you could go with a Corsair C70 or a Rosewill Blackhawk.
What about MSI?
You can probably find some 1600 Ram instead of 1333 that might even be cheaper depending on the brand.
http://pcpartpicker.com/p/QNvK
Just trying to give you some alternative ideas. I don't want to force you from what you want. It just seems the money for the case could go into making your machine ridiculously amazing.
