so the Motherboard im getting says the memory has to be DDR3 1333+ (OC)/1066..
so my thing is i never seen 1333+ what does that mean?
MOBO LINK - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128565
1333 is the clock speed of the ram. 1333 Mghz
example
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233132
It means that it can handle memory speeds of 1333Mhz and up when you overclock the CPU.
Don't get that board though. It is really terrible. There are no good AM3+ microATX motherboards.
Going with a 6 Core than get an Asus M5A97 R 2.0
8 core get an Asus M5A99FX Evo/Pro
my price point is 60 bucks..so ya.
You may want to try PCPartspicker.An look for a cheap motherboard with good reviews.I always check Newegg because that gives a lot more info of what your buying.I recommend not clicking any links to it.Just do a google search.
