Hey Logan How does my gabecube Look?
Built a gabecube, it needs a bit more work but the basics are there, I still need to drill vent holes and build a motherboard tray but I hope to make it my main PC when I get the money for it. If possible could you loan me a machine shop and a nice gauge of steel so I can make a proper welded box? thanks. I'm also not 100% if that cooler is going to fit, I need to put my PSU in and do some measurements, the box dimensions are 8x8x8"
