He needs the whole nine yards, monitor, keyboard, mouse, headset, windows, and PC. He has a budget of 700$. Try to keep parts coming from Newegg and amazon. It's just where He's most comfortable buying from.
What I got so far:
http://pcpartpicker.com/p/2iwSW
get the 7870 instead, its on promotion for 159 bucks (30 dollars increase).
Hope i helped.
http://pcpartpicker.com/user/tacticallemur/saved/2xkS
This is a little more money than your build but only because it doesn't have all the mail in rebates. It's basically the same money out of the gate. It is a pretty big improvement in performance with better components overall.
You can save a little money here and there if you want. You can get a 750k instead or a cheaper 50 dollar fm2 motherboard. The fm2+ will allow and upgrade to steamroller CPUs. You could step down to a 7850 also but the 7870 is amazing for the price. The xfx psu is better quality than the corsair. If you don't mind the mail I rebates then evga has some super cheap psus for like 29.99 after rebates.
http://pcpartpicker.com/p/2iKNf
tacticallemur is a good build for the money, but If your buddies budget is a tight $700 this build may work. Since the R9 came out prices have been dropping on the 7xxx GPU. I assume he wants to do some gaming a 7790 will get the job done but he's going to be happier with a 7850/7870. I don't know what your timeframe is but shop around lot of good deals to be had.
This is practically perfect, thank you man!
