so how all over the place is this http://pcpartpicker.com/user/agera/saved/gJZWGX
.... i was wondering why that build was so expensive, then I saw the 295x2.... sorry but don't do that build.
http://pcpartpicker.com/user/agera/saved/LgMTwP this is actually closer to what i want just debating on 270 or 280
is this a Budget build? cause I DEFINITELY wouldn't even consider putting that R9-295x2 with that Quad-Core FX chip and that Power-Supply.
Here's what i'd recommend.
http://pcpartpicker.com/p/rtNf23
i might just get that
